Balanced cable and GCX
Legacy
Post by Legacy »
Could balanced cables with stereo plugs can be used with GCX?
Legacy
Re: Balanced cable and GCX
The GCX jacks are all unbalanced, mono. There is a Stereo Upgrade that will convert 4 of the loops at a time to TRS jacks which will support stereo or balanced signal paths. Give us a call if you would like to add a Stereo Upgrade to the GCX.
