Pedal order for GCX?
CAR-15
Post by CAR-15 »
I have the following pedals in my GCX. They go from loops 2-7 and here is the current order"
Guitar plugs straight in to the input of channel 2, then the pedals go like this:
EHX LPB boost
EHX Micro POG
EHX Doctor Q - Autowah
MXR Carbon Copy delay
MXR phase 90
MXR Auto Q - Autowah.
Then out to the amp.
Seems like the LPB Boost isn't doing *. Maybe its a bad pedal?
When I try to use my Delay and Phase 90 on the clean channel it sounds muddy.
Just not sure if the pedals need to be in a certain order.
nyteowl
Re: Pedal order for GCX?
Post by nyteowl »
Pedal order is totally subjective, and I tell everyone the same thing: Put them in whatever order sounds best to you.
I would, however, suggest you experiment with where you put the boost in your signal chain. I think you'll find it works better farther in, as first in line I suspect all it's doing is boosting the guitar signal you're feeding to the Micro Pog.
Meanoldfireman
Post by Meanoldfireman »
Double check the cables in the loop. It might not be the pedal.
