GCX Channel switching
Legacy
Post by Legacy »
Hi there
Is there any way to switch 2 channel amp without using 2 loops of GCX?
Is it possible to use only on loop?
nyteowl
Re: GCX Channel switching
Post by nyteowl »
Nope, and nope.
Meanoldfireman
Post by Meanoldfireman »
What kind of amp? If it just needs one contact to ground, yes you can.
nyteowl
Post by nyteowl »
Meanoldfireman wrote:What kind of amp? If it just needs one contact to ground, yes you can.
But only if the amp wants a momentary switch, no? Can't say as I've ever seen an amplifier foot switch that uses momentaries, but then again my Profiler does, so maybe it is possible. I've been wrong before.
Meanoldfireman
They latch. I've used them to switch channels on a MB express 5:50 and 2 loops to switch between the 3 channels of a TGA-3.
Legacy wrote:Hi there
Usually this is done with just one loop since it is really just a simple Channel A/B happening to make the change.
What amp are you looking to switch?
