GCX Channel switching
Posted: Sun Jan 17, 2016 11:39 am
by Legacy
Hi there
Is there any way to switch 2 channel amp without using 2 loops of GCX?
Is it possible to use only on loop?
Re: GCX Channel switching
Posted: Sun Jan 17, 2016 12:35 pm
by nyteowl
Nope, and nope.
Posted: Thu Jan 21, 2016 1:51 pm
by Meanoldfireman
What kind of amp? If it just needs one contact to ground, yes you can.
Posted: Fri Jan 22, 2016 12:51 pm
by nyteowl
Meanoldfireman wrote:What kind of amp? If it just needs one contact to ground, yes you can.
But only if the amp wants a momentary switch, no? Can't say as I've ever seen an amplifier foot switch that uses momentaries, but then again my Profiler does, so maybe it is possible. I've been wrong before.
Posted: Fri Jan 22, 2016 12:55 pm
by Meanoldfireman
nyteowl wrote:Meanoldfireman wrote:What kind of amp? If it just needs one contact to ground, yes you can.
They latch. I've used them to switch channels on a MB express 5:50 and 2 loops to switch between the 3 channels of a TGA-3.
Posted: Fri Jan 29, 2016 5:51 pm
Legacy wrote:Hi there
Usually this is done with just one loop since it is really just a simple Channel A/B happening to make the change.
What amp are you looking to switch?
