Control Switcher with GCX with Mesa Mark IV and GCP
houston1
Post by houston1 »
Currently trying to program my Ground Control Pro with my rack mounted Mesa Mark IV and GCX audio switcher. Im having difficulties setting the bottom 4 buttons on the Ground Control Pro for channel changing the Mesa. I have a voodoo lab control switcher plugged into the 1/4 channel outputs of the Mesa running midi into the GCX audio switcher. I use the top 8 for a different arrangement of stomp boxes running in the GCX.
From what i understand the control switcher acts as a "second gcx" when programming but i seem to be stuck.
Could anyone help with suggestions on how to program the channel changing with this set up?
Re: Control Switcher with GCX with Mesa Mark IV and GCP
Have you enabled GCX#2 within the Ground Control Pro? If so, when you are editing a Ground Control Pro preset you will see the GCX#2 screen... when you are on this screen you will be able to use Instant Access buttons 1-4 to select the correct Control Switcher "loops" then save the preset.
Let us know if you get stuck!
Christoffer.N
Post by Christoffer.N »
Hi houston1!
Im not sure if this is for any help but any way!
Back of your Mark V you you use the external switching for channel 2 and 3 to the GCXS's Out puts.
Check 3channel amp switching sheet.
Thats how I switch my 3channel Recto.
Then you hit IA 2-8 on your GCP and select like 7 to control number 7 on your GCXS. save!
Then you select bank 1 (GCP) "heavy" and your 2-8 presets that you wanna run.
Like bank 1 with 2,3 and 8 on your GCP hit edit save Y
example: bank 1 with 2-BossNS, 3Overdrive-pedal, 8Channel 3 on your Mark V.
Regards Chris!
