GCX & Amp Channel Switching Help
Posted: Sun Oct 18, 2009 5:38 pm
by Yomko
I was wondering how to use amp channel switching with my Marshall Mode Four Head and the GCX/Ground Control?
The Mode4 doesn't have Midi or separate channel outputs so how can I set-up channel switching?
Is this possible with my amp?
I appreciate any help and hopefully this makes sense.
Re: GCX & Amp Channel Switching Help
Posted: Thu Oct 22, 2009 10:58 am
The Mode Four uses a 15 pin connector for the footswitch. You will need a cable made that mates with the 15 pin connector and breaks out to multiple 1/4" mono ends. There will be one 1/4" end for each switchable function. Marshall should be able to provide the pin out to whoever you have make the cable for you.
Posted: Sun Nov 08, 2009 2:22 am
by jmpacheco@mac.com
Hi. I have the same issue. Who could make a break-out cable of this sort. Is there any solution you can just buy to control the mode4 with the GCX.
