Setting up GCP, Expressoin Pedal and GMAJ2 as Harmonizer
Does anyone have their GCP and a GMAJ 2 setup to be harmonizer with an expression pedal? If anyone has the parameter settings for a good harmonizer effect that can be accessed with an expression pedal, please let me know what those parameters are...
Bend your will to learn midi, then you can bend midi to your will...
Re: Setting up GCP, Expressoin Pedal and GMAJ2 as Harmonizer
The G-Major 2 has a "Whammy" setting and getting it set up is shown in the G-Major 2 User Manual in the Mod Menu section. Look to External Control Using Modifiers, then the Assigning an expression pedal as a Whammy example.
I have removed my 2nd expression pedal and am going with one EB jr... I have added a Morley Wah in its place... This is due to space constraints on my board.
I have established a harmonizer setting on my G MAJ 2 and renamed it: harmonizer. Clever, huh? lol
So, what I can do is setup one of my presets within a bank to recall my harmonizer setting on demand.
What I wanted to do initially is be able to use an expression pedal and bring in a harmonizer effect-I get what I need using the way I am doing it now though...
Be like Gumby-stay flexible!
