GCP, G-Major 2 and Instant Access.
Posted: Wed Oct 21, 2009 1:04 pm
by zebopdin
Hey all,
Riddle me this: The G-maj. can only run 1 effect per block at a time (i.e. you can't have a preset with two modulation fx (chorus and flange) at once. So, does this mean that if I want to assign two instant access switches on the GCP (one for chorus and one for flange) I essentially have to build two presets (one using chorus and one using flange). Is this correct?
I guess another way to think of would be that the instant access switches only switch the effect "block" off and on. The actual "effect" that is turned on or off is determined by the preset. Am I right?
Thanx in advance!
Re: GCP, G-Major 2 and Instant Access.
Posted: Wed Oct 21, 2009 4:38 pm
Correct. The Instant Access buttons will control the effect blocks on a G-Major or G-Major 2 and not necessarily the individual effect types within that block. It is in a G-Major patch that you would decide if the block will be chorus or flange.
John C.
