Power requirements for GCP (phantom power)
Posted: Fri Jan 13, 2017 8:38 pm
Using GCP with a Hughes & Kettner Grandmeister using its phantom power and 7 pin cable. The GCP works for a few minutes and then the lights get dim, thing starts schizzing out, and then I start getting crazy control messages being sent.
Unfortunately the solution seems to be plug in the GCP to a wall wart. On it's own power it works fine with no glitches.
H&K Manual lists phantom as 20VDC at 150mA on its midi in port. Just curious what the spec requirement is to power this GCP on phantom.
Anyone know someone that makes a box that you can plug a wall wart into back at the rack and have it apply power to the correct midi pins?
Curious if you have seen this before with the HK amps.
Thank you
Thank you
