Original Ground Control v.2 and two pedal switches.
alfonso
Post by alfonso »
Hello, I'm running very well an old Ground Control v.2 with basic memory with a Pedal Switch. Can I control a second Pedal Switch too?
Thanks.
Re: Original Ground Control v.2 and two pedal switches.
The Pedal Switcher acts as if it were 1/2 of a GCX when used with any Ground Control. Multiple Pedal Switchers will auto assign themselves as loops 1-4 or loops 5-8 depending on their order in the MIDI path. The original Ground Control with the standard memory will control one GCX. The original Ground Control with the 8k Memory Upgrade, or a Ground Control Pro straight out of the box, will control 4 GCX switchers.
alfonso
Post by alfonso »
Great...this means I'll get a second pedal switch! Everyone's happy! ;)
