Help me setup my rig
mmiles4u
Post by mmiles4u »
I am running a Bogner XTC with a 2x12 Mesa cab, I have a rack with 2 Voodoo labs GCX, a TC G-Major, an ISP Decimator, a Line 6 M13 and 6 stompboxes on 2 rack shelves...all controlled by a Ground Control Pro.
I have it all working 95% but can't figure out how to setup an expression pedal to control the M13 or the TC G-major.
Any one know how to do this???
Mark
Re: Help me setup my rig
In the Ground Control pro manual, check out the Pedal section under Setup Mode to enable the expression pedal. Then check out the Using Expression Pedals section under Edit Preset for assigning the device to be controlled and the function performed for any given Ground Control Pro preset. After that, let us know exactly where you get stuck.
