Behringer XR4400 Multigate Pro and GCX
Legacy
Post by Legacy »
Hi
Behringer XR4400 Multigate Pro has balanced inputs and outputs.
I am thinking to get one but all my cables are mono and I am just wondering can I use balanced cables with GCX....
Thanks a bunch
Re: Behringer XR4400 Multigate Pro and GCX
The GCX does not support balanced connections without modification, however does whatever else you are interfacing the XR4400 to support balanced connections? Likely it is not needed at all if this is a guitar rig.
