Running two amps with GCX with Radial bigshot ABY
Posted: Mon Nov 30, 2009 2:10 pm
I have a dual rec and I am wanting to use a second amp for leads. I've heard there can be noise issues involved with doing this so my question is should I use the radial bigshot aby to switch between the amps? If so, how do I hook up this pedal in the GCX? I don't want to play both amps at once, only one at a time. I just want to figure out the best possible way to run these. Thanks a lot.
