Control Switcher Issue?
Posted: Mon Sep 25, 2017 9:59 am
Hello Forum:
This past Saturday I received a new Marshall DSL40C, Line 6 M13 and VooDoo Lab Control Switcher so the M13 can change channels/reverb on the amp. Played the amp w/the M13 Saturday and no issues. Even at loud volumes the amp was relatively quiet.
Saturday night I setup the Control Switcher and was able to successfully change channels on the amp when using the M13 Latch Scene mode. It was late so volume was low and I did not test the reverb.
Sunday (yesterday) I played at loud volume again and the hiss on the gain channel was horrible. Anything past 4-5 on Lead 1 was incredibly noisy. Lead 2 is un-usable. Also, discovered that the reverb no longer works on either channel (it was working on Saturday). I did try resetting the tubes thinking maybe one came loose during shipping but that made no difference.
Sweetwater is replacing amp so that's good. My concern is what caused the amp to fail and the only difference between Saturday and Sunday was adding the Control Switcher into the signal chain. It's a pretty simple device so logically I don't see how that could affect it, but I have to admit I'm concerned about trying it with the new amp.
Have there been any reported issues with the Control Switcher and/or is there something I should or should not be doing when I set it up? Is there a way to test signal voltage, etc? As far as setting it up I changed the configuration to accept both PC and CC signals, connected the MIDI cable from the M13 to the Control Switcher and connected the Insert cable from the Control Switcher to the amp footswitch jack. It's really impossible to mess that up.
Bob
Bob
