I noticed the software has a G-Force option, similar to the Flextone option, and the G-Force has a GCP setting as well, but it appears I have to configure instant access buttons manually. Is there a chart for the G-Force settings, like page 22 of the manual has for the Flextone? I see all of the presets match the presets for the G-Force, but am I missing anything else?
Is it possible to program G-Force bank changes into GCP presets?
Also, you mention an update in another thread. Is it possible that you will give us an 8 preset and 4 instant access option in the future?
Thanks.
-Ben
GCP and G-Force
Re: GCP and G-Force
The G-Force default program found in the Ground Control Pro will assign the Instant Access buttons to individual Control Change messages, however you will have to assign what effects these control within the G-Force as it has no default controller assignments associated with the effect blocks. The Ground Control setting within the G-Force is for the original Ground Control and not the Ground Control Pro.
