GCpro and Eventide Pedals: Change presets /w instant access?
johnnyslomo
Post by johnnyslomo »
Hi! I want to build a rack solution for my pedals and use the GCpro as Midi device. But I want to change the Eventide's programs with an instant access switch to get a kinda stompbox mode,where I can switch e.g. the chorus on and off or switch between e.g. chorus and rotary.
Is this possible or are there any other solutions ?
Re: GCpro and Eventide Pedals: Change presets /w instant access?
Enabling individual effect types within a patch on a processor is usually done with the Ground Control Pro Instant Access buttons by programming them to send a Control Change message to the intended device. You will have to check that the pedal you are using has the capability to respond as you wish to this command.
scottburrow
Post by scottburrow »
Will you ever be adding the ability to have a program change as well as a control change per Instant access button?
scottburrow wrote:Will you ever be adding the ability to have a program change as well as a control change per Instant access button?
I doubt it as this can be done to some extent with a Ground Control Pro preset. Do you have a device that requires this?
scottburrow
I have 3 eventide factor pedals and the CONTROL CHANGES that I can make are
BYP – bypass the unit
BK + - Increment bank number
BK - - Decrement bank number
Tap – Tap tempo switch function
FLX (pitchfactor) – Toggle flex/learn function
BRK (modfactor) – Toggle Break function
RPT (timefactor) – Repeat function
REC (timefactor) – Looper record
PLY (timefactor) – looper play
STP (timefactor) – looper stop
P/B – Toggle between Play and bank mode
KB0….9 – Parameter control knobs
FS1 – left footswitch
FS2 – Middle footswitch
FS3 – Right footswitch
PDL – Foot Pedal
ACT – Active(enable effect –unbypass)
Tog – toggle between active and bypass
TUN – Enable/Disable Tuner
If I had the ability to make a program change along with the control change I could change the effect on an instant access switch from one effect to another ex. Change to patch 2:1 (short delay) to 2:2 (long delay) etc-. I want the preset to have a default patch but also be able to use the instant access buttons to change to a different one. How else can you get the ability to use a multi function device such as this with an instant access button, how do other multi function Processors do this such as G-force etc-?
Changing from 2:1 to 2:2 is changing patches which requires a Program Change. Program Changes are what a Ground Control Pro preset will send. If you wanted to load patch 2:2 you would simply recall a new Ground Control Pro preset that does so. If you also needed to activate something that you had an Instant Access button programmed to control while loading patch 2:2 you could set that particular Instant Access button to Transmit With Preset and enable it within a Ground Control Pro preset. Whenever this preset was recalled it would send the Program Change as well as the programmed state of the Instant Access button via a Control Change message. I hope that helps.
scottburrow
That makes sense, thanks John.
