Use Exp Jacks as extra IA Switches?
Posted: Mon May 18, 2009 4:17 pm
by Paul A
Josh
Since my success with the Damage Control Tap tempo problem, I have a different problem. I am running short on IA switches on my GCP.
Would it be possible to gain 2 extra IA switches by using the Pedal jack sockets wired to a switch? I appreciate that the on/off status of such a switch would not be saved within a GCP preset.
Paul A
Re: Use Exp Jacks as extra IA Switches?
Posted: Mon May 18, 2009 6:42 pm
by Josh Fiden
Very good question! Yes, you can. However, you have to be a little careful since those inputs were intended to have a potentiometer on them, not a switch. There is no debouncing (switch contacts normally do not make and break cleanly) and it is possible to see values besides just 0 and 127. Many people have successfully done this, you just can't control everything this way.
Josh Fiden
Founder / CEO
Posted: Wed Aug 12, 2009 12:28 pm
by jmcthe3rd
Josh,
I have the older style Ground Control. I would like the ability to use the EXP Pedal jack as an instant access to turn off and on loop 1. I thought this would be possible as I setup the Ground Control to send on midi channel 16. When I'm setting up the preset I have the device set to the device using channel 16 then 80. I then setup pedal one to CTL 080. I have confirmed that the switch toggles the CC messages from 0 to 127 but, nothing seems to happen. Loop 1 never activates or de-activates. I setup the Ground Control using the Bank 4 option as a work around but, I'd really like to be able to have access to 10 presets then turn on loop 1 when needed. (I have just an affects pedal in loop 1) Thanks for the help!!
Posted: Wed Aug 12, 2009 2:19 pm
by Josh Fiden
jmcthe3rd wrote:Josh,
That doesn't work. When you assign another device to MIDI channel 16, Ground Control will move the GCX to a different channel to avoid conflict. If you need 8 instant access, you need to either upgrade to a Ground Control Pro or find a used Ground Link.
Josh Fiden
Founder / CEO
