Control Switcher
Posted: Sun Apr 15, 2018 11:38 am
by TV_Brains
I am having trouble with my control switcher taking commands from my px8+. I haven't changed any settings the only difference has been taking my set up from home to practice and back. Could it be my midi cable is not working or is there a step by step trouble shooting method to find out what's wrong? I should also note that when I go to use the option to save a setting on the control switcher by pressing 1 and 4 it does not flash like it normally should do.
Re: Control Switcher
Posted: Wed Apr 18, 2018 3:45 pm
If the LEDs are not flashing that would suggest that the Control Switcher is not receiving a Program Change message on the assigned MIDI Channel prior to attempting to save.
What is your exact MIDI routing? If you connect directly from the PX-8 MIDI Out to the Control Switcher MIDI In do things start to work correctly?
Posted: Thu Apr 19, 2018 5:02 pm
by TV_Brains
It is routed in that manner, no other devices in between. I haven't changed any settings so could it possibly be my MIDI cable?
Posted: Fri Apr 20, 2018 9:49 am
It could certainly be the MIDI Cable, always worth a test with a different cable.
If it still isn't working check that the PX-8 and Control Switcher are still programmed as you want them. How are you powering the Control Switcher and PX-8?
Posted: Sat Apr 21, 2018 11:40 am
by TV_Brains
Control switcher is being powered by the included adapter and the px8 is being powered by the pedal power 2 plus on the L6 (either channel 5 or 6)
Posted: Mon Apr 23, 2018 10:31 am
Is there any chance you could give us a call while you are with the gear so we can troubleshoot it "live"?
http://www.voodoolab.com/contact.htm
Posted: Tue Apr 24, 2018 3:53 am
by TV_Brains
Sure I can do that when I get out of work today
