MARSHALL JVM 410 GFORCE+GROUND CONTROL PRO+GCX AUDIO SWITCHE
Good morning I come d ' to buy MARSHAL JVM 410 h and I not has make it work with the G FORCE, GROUND CONTROL PRO and GCX Audio Switcher thanks for to help ME
Re: MARSHALL JVM 410 GFORCE+GROUND CONTROL PRO+GCX AUDIO SWITCHE
Your JVM and G-Force are MIDI devices. Each MIDI device will need to be set to respond on its own, unique, MIDI channel. Within the Ground Control Pro you will name each device and set the MIDI channel each device is set to respond to. This is explained in the Ground Control Pro Manual under Device Name/Channel in the Setup Mode section.
