Useing Vintage Amps with GCX
Bob Barcus
Post by Bob Barcus »
I have alot of vintage pedals and rack gear Do I need a amp with a FX loop or can I use 2 vintage amps one for my pedals and the other for all the rack gear.I will list it all if you can help me
Re: Useing Vintage Amps with GCX
Check out the rig diagrams here... http://voodoolab.com/gcx.htm
The GCX will switch effects in front of an amp as well as effects within an effects loop with no issues.
