2 GCX - MIDI question
Posted: Sat Jan 09, 2010 12:56 pm
Hi - I am finalizing my rack and attached the two GCX worksheets for the layout. I have two questions:
1) Will the Feed Thru from GCX #2 act as a DRY AMP line out (no effects)
2) For the MIDI units, if they are connected via MIDI (each assigned a unique MIDI channel), can I utilize one loop? Or does each MIDI rack unit need its own loop?
As always, thank you! (Diagrams attached...recommendations welcomed)
