I have the GCP and GCX.
I attach the pedals and the heads of amplifier:
Guitar>Loop1 dyna comp>Loop2 phase 90 >Loop3 TS-9 >Loop4 head jcm2000 dsl100 >Loop5 head mesa dc-5 > Loop6 ch jcm 2000 > Loop7 ch dc-5 > Loop8 Intellifex on-line (send return) > 4x12
how can I connect everything? and can i use this Expression Pedal 1 Volume Pedal BOSS FV-500H connect to the GCX?
connect two amplifier
Re: connect two amplifier
Do you want only one amp at a time or will you need to play through both amps at once?
Does the Intellifex need to be used in the effects loop on both amps?
The Expression Pedal ports can be used with your volume pedal to control parameters within your Intellifex.
-Possibly both amps.
-sure, possibly both amps.
thanks again!!!
thanks again!!!
What do you think? The cable is correct?
5.
in: 1 Cable Y
Send: IN MESA DC-5
6.
in: 2 Cable Y
Send IN JCM 2000
5.
in: 1 Cable Y
Send: IN MESA DC-5
6.
in: 2 Cable Y
Send IN JCM 2000
You got it!
The correct Y cable will have mono connectors on all three ends.
