Greetings,
I am a new Voodoo Lab/ pedalboard owner, thus this question that probably has a simple answer.
I just got a Voodoo Lab Pedal Power 2 Plus supply, which is mounted in a Pedaltrain ll.
What do I do if I want to use more than (7) 9V pedals?
Would I have to use an additional Voodoo Lab power unit?
Currently I have:
MXR Phase 90
MXR Distortion Plus
MXR Dyna Comp
Cry Baby Wah
Morley Mini Volume
Rogue Chorus
Rogue Blues Distortion
I would also like to add an MXR Carbon Copy Delay as the seventh pedal.
Pete
Voodoo Lab Pedal Power 2 Plus Question
Re: Voodoo Lab Pedal Power 2 Plus Question
you should be able to run eight (8) 9V pedals from the Pedal Power 2+. As long as the current draw isn't too high (more than ~150MA per pedal) you should be good to go I think. Also if you have a pedal (or in my case a wireless unit) that requires more milliamps. Just use outputs 5 and 6.
Hope that helps.
DJ
Hope that helps.
DJ
Mothra J Mothington III
