Tc g mayor 2 with GCP and Gcx help please
rockman8812
Post by rockman8812 »
Hello.
how can i do to save some presets of my g mayor 2 in my ground control pro?
for example:
_'''''''''_
1 2 3 4 when i press my preset 1 of the GCP i would activate preset 34 of the
5 6 7 8 g mayor 2 and when i press preset 2 i would activate preset 50 of the
9 0 3 4 g mayor 2 .
Thanks a lot.
Re: Tc g mayor 2 with GCP and Gcx help please
Straight out of the box these two should already be working together. If you want to change the patch that a Ground Control Pro preset is recalling then simply do this:
1. Call up the Ground Control Pro preset you want to edit.
2. Press and hold the Edit button.
3. Once the screen changes you should be able to type the patch number you wish to recall.
4. Press the Edit button to exit then press Yes to save.
If you haven't changed anything within the Ground Control Pro the above should get you started. If you want the most out of this setup I suggest reading both the Device Name/MIDI channel section under Setup Mode and the Assigning MIDI Program Changes section under Edit Preset in the Ground Control Pro manual. Good luck!
rockman8812
Thanks a lot men i would work on this.
