4x4 for Switchblade 8F, PitchFactor, EHX Superego & Boss?
luca9583
Post by luca9583 »
Hi folks
I have a board consisting of the following:
Soundsculpture Switchblade 8F (250ma minimum at 9VDC either polarity, 2.1 mm plug)
Eventide Pitchfactor
EHX Superego (140mA at 9VDC with a center negative plug)
Boss Tuner
Boss OC3
Empress Para Eq (Boss)
Will the Pedal Power 4x4 power the whole board and if so which would be the correct power outputs to use?
Re: 4x4 for Switchblade 8F, PitchFactor, EHX Superego & Boss
A Pedal Power 4x4 would be great for this setup. The Switchblade 8F, PitchFactor, and Superego would each connect to the High Current 9V outputs. The tuner, OC-3, and ParaEq can each be powered from any of the remaining 9V outputs.
