Will the Sparkle Drive tolerate 12 volts from the PP2+? Overdrives are said to get more headroom if the voltage is upped... the overdrives that can take it, that is... or should I just leave it at 9 volts?
Kind regards
Rolf
Sparkle Drive - will it tolerate 12 volts?
Re: Sparkle Drive - will it tolerate 12 volts?
12V should be fine for the Sparkle Drive. I doubt there will be much of a sonic difference at the higher voltage. Try it out and let us know what you think.
