Amp Selector
jimi8899
Amp Selector
Post by jimi8899 »
Hi, I believe I posted my question under the wrong topic.. basically, my Amp Selector is stuck to A/B mode even though there is nothing plugged into input B. With only one guitar plugged into Input A, I can only select amp1 &2 - 3 &4 are muted. thnx - James
Re: Amp Selector
Try working a cable in and out of Input B a few times. Input B is a switching jack that changes the signal path when a cable is connected to it. It may just be that the contacts are dirty from non use. If that doesn't do the trick just give us a call and we can get it in for a check up.
jimi8899
Re: Amp Selector
Post by jimi8899 »
Hi John, so easy... It worked! thanks so much for assisting! Cheers, James
