Setting up instant access on Ground Control Pro, G Major
thorny
Post by thorny »
Could anybody walk me through setting up my Ground Control pro with my G major. I have a GCX switcher in the rack that controls my 2 dirt pedals and my G major. I want to set it up to use the 4 presets per bank (the bottom 4 buttons) with the other 8 buttons for instant access. I dont use the channel switching on my amp preferring to just use the clean channel and then use the different distortion pedals for varying amounts of gain. I already have my presets configured in the G major. So I want to setup number one on the Ground control as my clean, 2-crunch,3-rhythm,4-solo. Then use the other 8 buttons as instant access to turn on/off the effects blocks in the G major. Ex. 1-chorus,2-delay,3-reverb,4-pitch/detune, 5-phaser, 6-Flanger, 7-compressor,8-tap tempo. If anyone out there could explain how to do one of the presets and one of the instant access it sure would help. Thanks!!
bodomchild88
Re: Setting up instant access on Ground Control Pro, G Major
Post by bodomchild88 »
check this out. i had some similar issues. http://www.voodoolab.com/forum/viewtopic.php?f=9&t=339
