So I love the idea of the rock man power station that has 9vac as well as normal ac outlets. So I opened up my furman power conditioner and there is tons of unused space. So I am planning on taking the guts of my pedal power ac and mount them inside the furman chassis and drill some holes on side to get to the 9vac outlets of pp ac.
My question is this, any issues of having both the furman and ppac power toroidal transformers in the same box? Everything would be hooked up the same. It just would be inside instead of outside. Wasn't sure if the transformers magnetic field would play havoc with each other
pedal power ac mounted inside a furman.
- Contact:
Custom Audio Amplifiers PT100
Bogner Ecstasy 101B
Carvin electric guitars
Bogner Ecstasy 101B
Re: pedal power ac mounted inside a furman.
I doubt there would be any issue having the transformers close together... however use extreme caution here since these devices are using mains voltage! Make sure you know what you are doing before zapping anything or yourself
