Will The Behringer FCB1010 work with GCX
ratsgym
Post by ratsgym »
I'm getting the GCX and I have a Behringer FCB1010 and have been told It should work until I get the Ground Control. Is this true and how hard is it to sync up?
James Santiago
Re: Will The Behringer FCB1010 work with GCX
Post by James Santiago »
ratsgym wrote:I'm getting the GCX and I have a Behringer FCB1010 and have been told It should work until I get the Ground Control. Is this true and how hard is it to sync up?
Our tech has addressed this a couple times on the forums. Here's one of his last responses to this question. Also, you can search these forums as well just in case someone else has come up with a better solution.
http://www.voodoolab.com/forum/viewtopi ... nger#p1098
JS
James Santiago
Vice President - Voodoo Lab
