Hi there,
I did a re-jig again, I took out the Switchblade 16, they take so much away. Now the whole preamp section can push the power amps harder. It sounds so much better. I have utilised the Rane Mixer again and glad I have, TC Electronic G Major 2 is in the loop of the SM82S.
I’ve got the Recto Recording and 2:100 totally seperate now, they do their own thing but it is still controlled by the GC Pro’s and the Mini Switch Gizmo.
The rest of the system is controlled by the GCX, Voodoo Gear Rocks!!
I have changed the order to make wiring a lot easier and more tidy!!
I have rewired the pedal drawer to tidy it up a bit!!
Well hope you guys and gals like the pics.
Rack on its way
Re: Rack on its way
And some other stuff.
Re: Rack on its way
Well I’ve been at it again and switched it all around. I have 2 different racks now each with its own power supply, power amp and 2 preamps. Just need another couple of cabs
It’s not as good as Nice Rack Canada, but hey, it’s alright.
Re: Rack on its way
Hey man, Nice Rack!
Re: Rack on its way
Looks lik an awesome battlestation! I'm still far from it, but I hope I'll reach that level some day!
Re: Rack on its way
Cheers Yak, it goes alright.
Just grab stuff when it comes up cheap or do some haggling. You’ll get there
Re: Rack on its way
Here’s the latest setup
Re: Rack on its way
All I need now, is the ampete amp & loop switch, and I hopefully will be done.
Rig so far.
Currently I run between 2 heads, although the 3rd is on the way. Just need a really good switcher that will switch amp, so I can use 1 fx rack, and a couple cabinets.
Still have the option to add a few more pedals to the fx tray if needed
- Attachments
- 62DB03ED-90E0-4C00-B22E-2F92329E7101.jpeg (30.92 KiB) Viewed 15375 times
- A480C717-5871-4011-AB4F-421F8CD2CCD5.jpeg (26.59 KiB) Viewed 15375 times
Re: Rack on its way
Couple more pics
- Attachments
- 90ABB861-B623-4CF5-AD65-32D74DDC67DD.jpeg (31.78 KiB) Viewed 15374 times
- 7E8CAC02-C78E-412A-97AD-A9D376F79520.jpeg (29.33 KiB) Viewed 15374 times
- 61BE0DE0-EFAA-4E83-890B-ADF1B6DC4EB8.jpeg (30.92 KiB) Viewed 15374 times
Re: Rack on its way
Awesome rig you’ve got there
Need to get myself a couple of those Mesa 2x12 cabs.
