Will a Truetone CS12 power brick fit under Dingbat medium pedalboard?
Jarvismcjigglestein
Post by Jarvismcjigglestein »
The dimensions for this power supply are 8.12” x 3.37” x 2”.
Also, is it safe to mount the power supply with something like gorilla tape (holds up to 30lbs) since I'm assuming the pedal boards mounting hardware will not fit this unit?
Re: Will a Truetone CS12 power brick fit under Dingbat medium pedalboard?
It would be a tight fit, but it should make it without the power supply touching the floor as long as you are using a low profile mount method. I also cannot say for certain how well the switches will fit in the holes in the board. I don't know how well tape of any sort will work, but it's worth a shot I suppose. The board itself is aluminum so if you wanted to make some brackets drilling holes in the board wouldn't be too difficult.
SpecialKM
Post by SpecialKM »
CS12 fits fine and the power connection lines up with the cutout. I mounted mine with a liberal amount of dual lock and you’d need a crowbar to get it loose.
