Hello,
I have the Boss DD200 delay and need to know if it will work correctly to power it with any of the 1-4 plugs off the PP+2? Or do I need to use 5 or 6 or chain 5 and 6 together? The pedal has a current draw of 225 mA. Thanks in advance.
PP+2 Boss DD200
Re: PP+2 Boss DD200
To power the DD200 with Pedal Power 2 Plus, use output 5 or 6, DIP switch in the 9V (normal) setting with one of the all black (standard polarity) cables supplied.
Cheers!
Cheers!
Cheers,
Ben Resnick
Voodoo Lab - Tech Support
Ben Resnick
Re: PP+2 Boss DD200
Perfect!!!! You guys are the best!!!!
Re: PP+2 Boss DD200
Cheers,
Ben Resnick
Ben Resnick
