Hey there,
I cant find any information on channel switching in 2ch amp like Soldano SLO with Control Switcher
I have an SLO with an H9 in a loop with a FAS MFC 101. I want to use the Control Switcher to switch channels and add some effects at the same time with the H9.The SLO only has a 1-button footswitch that alternates channels. Can the Control Switcher "see" which channel is working and switch or not switch the channel?
As an examlpe, I want to create presets like that
1. Clean (SLO) + Dly (H9)
2. Clean (SLO) + Chorus (H9)
3. Drive (SLO) + Dly (H9)
etc.
Can Control Switcher do that or its just alternates channels, when footswitch is activated?
Soldano SLO + Eventide H9 + VL Control Switcher + MFC 101
Re: Soldano SLO + Eventide H9 + VL Control Switcher + MFC 101
Hi there,
Which Soldano SLO model do you have? Does it have the effects loop? Is the effects loop he switchable one?
The Control switcher can switch the SLO, via midi.I can receive PC and CC messages via midi and can control either 4 of the switches in any combination. If the SLO has a foot switchable effects loop, it can do this also. The H9 can be controlled via midi, with the midi through from the control switcher.
I’m just wondering what loop the H9 is in?
Give us some more info, ie. what model SLO and what “loop” the H9 is in.
And some other stuff.
