TC Plethora X5
Moonunit
TC Plethora X5
Post by Moonunit »
Quick question: can I power a TC Plethora X5 with a Pedal Power 2+ Using a current doubler? If so, has anyone here done that?
Thanks and best.
Rez
Re: TC Plethora X5
Post by Rez »
The TC Plethora X5 manual specifies a minimum of 600mA is required.
So, unfortunately... no, using a current doubler in outputs 5 and 6 will not suffice.
However, you could power it from the AC courtesy outlet with its adapter/wall-wart.
Cheers,
Ben Resnick
Voodoo Lab - Tech Support
