I recently went from 5 pedals to 17 total.
I have a pedal power 2plus and want to know what is the easiest way to expand to power all 17 pedals.
1 is the nova delay which I can plug into the power outlet on the 2plus.
The rest are Fuzz Face Mini, OCD, Tube Screamer, Deja Vibe, Hall of Fame Reverb, Super Chorus, Carbon Copy, Dynacomp, EP Boost, octafuzz, 5150 overdrive, supa-trem, evh flanger, evh phase 90, cry baby wah.
All seem to be normal plug and power level.
Looking for the least expensive way to get to 17, but still all isolated.
Do I need a whole new 2plus, does Voodoo Lab have an expander that is less $ or I have also looked at Gigrig?
Looking for guidance.
Thank you!!
Need More Power
Re: Need More Power
I think the Mondo or Pedal Power 3+ is for you. Both have plenty of ports and the Mondo has more for your growing pedals.
And some other stuff.
Re: Need More Power
With 17 pedals, using two supplies is likely your best option. You could use your Pedal Power 2 Plus together with any one of these:
Pedal Power Mondo
Pedal Power 3 Plus
Pedal Power 3
Pedal Power X8
Pedal Power 3
Pedal Power 4 x 4
Pedal Power 2 Plus
Note, if you add a second supply with 8 or fewer outputs, you may need to also use a couple Output Splitter Adapters, part# PPAV.
Hope this helps!
Pedal Power Mondo
Pedal Power 3 Plus
Pedal Power 3
Pedal Power X8
Pedal Power 3
Pedal Power 4 x 4
Pedal Power 2 Plus
Hope this helps!
Cheers,
Ben Resnick
Voodoo Lab - Tech Support
Ben Resnick
