Powering HX Stomp with Outputs 5 and 6 of Pedal Power 2
EEdpud
Post by EEdpud »
As the post says Im trying to power the Line 6 HX Stomp with the pedal power 2. I'm using the Voodoo lab cable adapter that combines outputs 5 and 6 with the red 2.5mm cable included and Im getting nothing.
Both outputs are switched away from normal. Any advice on getting it running.
Rez
Re: Powering HX Stomp with Outputs 5 and 6 of Pedal Power 2
Post by Rez »
Due to its high current requirement (at least 800m) with Pedal Power 2 Plus, the only option is to power HX Stomp (or HX Effects) from the AC courtesy outlet with its adapter/wall-wart (the DC outputs will not suffice regardless of any special cable).
Note, it is possible HX Stomp (or HX Effects) with one of these higher current capacity supplies: Pedal Power 4 x 4, Pedal Power 3, Pedal Power Mondo or Pedal Power 3 Plus, setup as follows: To power your HX Stomp (or HX Effects) use two 9VDC high current capacity (400mA or 500mA) outputs and a HX Current Doubler Cable
Cheers,
Ben Resnick
Voodoo Lab - Tech Support
