Line 6 relay g30 and Pedal Power 2 Plus
RolfK
Post by RolfK »
Hi, can the Line 6 relay g30 receiver be powered by one of the 100mA outlets on my Pedal Power 2 Plus?
Kind regards
Rolf
Re: Line 6 relay g30 and Pedal Power 2 Plus
Judging by the posted specs of the power supply I would say that yes, any output on a Pedal Power 2+ set to Normal should be able to power the G30.
RolfK
Post by RolfK »
Cool, thanks!
EddieRocks
Post by EddieRocks »
Hi.
I want one of these line 6 wireless units.
Bit confused.
You say it will be powered by a voodoo labs power 2 plus with a black lead. I've also read that I may need a doubler cable and 2 outputs.
Really confused.
The G30 should be OK on a single output. It is the G50 and up that will benefit from having a bit more current by using the Current Doubler.
