Right now for Power Supplies I have a PP2 (not the +) and a regular old PP as well as a PPAC that I don't use right now. I'm not sure if any of these can help me with what I need, or if I'll just end up using them for smaller boards sometime down the line.
I'm using the following gear and need to know what I need to power it.
Teese RMC3 wah (works fine on a 9v (PP2) out set to normal)
Sonic research ST-200 tuner (works fine on a 9v (PP2) out set to normal)
TC Nova Drive (12v @ 380mA)
TC Nova Dynamics (12v @ 300mA)
Eventide ModFactor
Eventide TimeFactor
None of the midi capable gear is using midi and I plan to keep it that way. I am hoping to use as few of the supplied wall warts as possible- within reason. The biggest wall wart offenders are the Eventides- which are huge! The Nova's aren't so bad. Maybe my only choice is a PP2+ with a small strip for the Novas? Maybe there's a better option?
any help with this is greatly appreciated.
thanks,
David
What PS(s) do I need for this setup?
Re: What PS(s) do I need for this setup?
37 people looked at this and no one has any info to share? JohnClark, want to take a shot at this list of gear and the power supply/ies it will take?
We do not currently have a device that would power 2 Nova pedals as well as 2 Factor pedals. However, I do have to ask... how much Tequila do you have?
Hi John,JohnClark wrote:We do not currently have a device that would power 2 Nova pedals as well as 2 Factor pedals. However, I do have to ask... how much Tequila do you have?
yes- I'm aware you don't have a (single) device to power all of this. If you did I would have bought it and not asked this question, looking for help.
I'm a long time VL user, and I'm looking for some assistance with this. Care to explain the tequila comment?
We see you have a Pedal Power AC that you do not currently use... perhaps there is something a certain Magician could do with this to help your current situation. The Tequila reference is because magic is not free and the only monetary unit we trust here in the depths of the Voodoo Lab R&D Man Cave is high end Tequila.
