wah pedal with gcx system
I presently use 6 stompboxes which are all used in the effects loop... i tried to hook up my wah pedal between the audio switcher and the guitar and couldnt access my fx loop... what is the right way to hook up my wah pedal?
Re: wah pedal with gcx system
Generally your wah pedal will be connected the traditional way, Guitar to Wah, Wah to "wherever you normally connect your guitar"...
In this case there really isn't enough information to know why you ran into troubles. If the above didn't help out, try filling out one of the blank diagram sheets with your current setup and post it here or email it to info@voodoolab.com. The blank diagrams can be found here http://voodoolab.com/gcxdiagrams/blank_ ... heet_p.pdf
