GROUND CONTROL x SONAR 6 - HELP ME JOHN CLARK !!!!!
Marcus
Post by Marcus »
He would like knowing if it lets to control a trace in the SONAR 6 through the Ground Control.
And since I must do.
Thank you !!!!!!
Re: GROUND CONTROL x SONAR 6 - HELP ME JOHN CLARK !!!!!
Sonar 6 will learn the MIDI messages sent to it for any of the MIDI controllable parameters.
Marcus
Post by Marcus »
Since I do that ????
Thank you .
I have never used Sonar 6 so I do not know how you perform the MIDI learn functions within the software. Perhaps this quote from the Cakewalk website will help you to find the proper section in their manual or be able to ask someone with proper knowledge of the software: "With SONAR's improved MIDI learn functionality, it's simple to create ACT configurations for any MIDI device." I hope that helps!
Marcus
Post by Marcus »
John ,
I thank for the help that has been giving to me.
It would like one more explanation.
What type of program of easy handling I might use for freeing my sequencer through the Ground Control.
I do assemblies of instruments in the Sonar and then I transform the trace in MP3.
Thank you.
Marcus
Post by Marcus »
Help me John !!!!!!!
I am afraid I do not understand what you are asking me to help you with.
Marcus
Post by Marcus »
Thank you.
I am afraid I cannot help you there. Perhaps someone on the Cakewalk forums can make this as easy as pie for you... http://www.cakewalkforum.com/forums/
Let us know if you have any more questions related to using the Ground Control Pro. Good Luck!
Marcus
Post by Marcus »
In fact I would like knowing about what you the program of the commonest and easy sequence of using what most of the persons use together with the Ground Control.
Thank you John !!!!!!
