How tp connect 1pedals, Mark IV w/channel switching, Lonest
smhlaw13
Post by smhlaw13 »
I need help connecting the following: 1 pedal (tube scream), TC g-force in loop of Mark IV with all three channel switching, and a Lonestar amp with a Carl Martin Compressor in the lonestar loop. I would like the amps to be independant of each other.
I have a GCX ground control pro.
Is it possible to get a diagram? I spent way to many hours trying to figure this out. I have always used the system described above without the lonestar. I cant get the lonestar to work.......Help.
Jon Wilder
Re: How tp connect 1pedals, Mark IV w/channel switching, Lon
Post by Jon Wilder »
smhlaw13 wrote:I need help connecting the following: 1 pedal (tube scream), TC g-force in loop of Mark IV with all three channel switching, and a Lonestar amp with a Carl Martin Compressor in the lonestar loop. I would like the amps to be independant of each other.
Are you wanting to run through each amp independently along with being able to run through both simultaneously (A/B/Y switching)? Or do you just want the capability of being able to A/B switch between the two and run through each one independently?
Jon Wilder
Voodoo Lab
Tech Support
