How to connect intellifex on gcx MIDI
nikbia
Post by nikbia »
Hi everyone
My question is:
If possible change the preset of intellifex on ground controll (NOT PRO).
My setup is:
1
in - guitar
send mxr dynacomp in
return mxr dycomp out
out - 2
in - 2
send mxr phase90 in
return mxr phase90 out
out - 3
in - 3
send ts808 in
return ts808 out
out - 4
in - 4
send ts9 in
return ts9 out
out - 5
in - 5
send ocd in
return ocd out
out - in MESA DC-5
out - 6 change canal DC-5
out - 7 change EQ DC-5
in - 8 Send DC- 5
send - intellifex in
return - intellifex out
out - return DC-5
With ground control works everything except the change presets of intellix
thanks all and sorry for my bad english ;)
Re: How to connect intellifex on gcx MIDI
Do you have a MIDI cable connected from the MIDI Out of the GCX to the MIDI In on the Intellifex? Do you know what MIDI channel the Intellifex is set to receive?
nikbia
Post by nikbia »
The connection MIDI is correctaly
The number MIDI is 15
SETUP MODE (ground control)
1.Intellif/15
But when enter in program mode and change the preset of intellifx it isn't responding.
If connect the ground control on MIDI IN the intellifex working properly!!!
Where is the problem?
Does the Intellifex show any MIDI activity when it is connected to the MIDI Out on the GCX? Do you have another MIDI cable you can try between the GCX and the Intellifex?
nikbia
Post by nikbia »
Great ....
Resolved, disconnect and connect the cable!
Thank you for everything!
