Question switching amp on gcx
nikbia
Post by nikbia »
Hello
I have two amps (mesa dc-5 and Marshall JCM2000 dsl) to be controlled by GCX.
I would like to manage the pre and power amps separately.
How can I do?
Thanks.
P.S.: Where can I find the empty image inputs writes for GCX?
Hazar
Re: Question switching amp on gcx
Post by Hazar »
You can find the blank form for laying out your connections on the GCX product page.
http://www.voodoolab.com/gcxdiagrams/bl ... heet_p.pdf
http://www.voodoolab.com/gcxdiagrams/bl ... heet_l.pdf
I have no idea how to do what you are asking though bro.......I am struggling myself.
The Effects Send jacks can be thought of as Preamp Output jacks and the Effects Return jacks can be thought of as Poweramp Input jacks. What exactly do you want to do here? Are you looking to be able to route either preamp section to either power amp section? If so, then the A/B Switching section of the GCX manual would be the best starting place to get up and running. Let us know if you run into any troubles.
