Using Pedal Switcher or GCX as an A/B switch
stoneboy26
Post by stoneboy26 »
Hey - is there anyway to use either of the above as an AB switch to change between 2 instruments?
eg. 1 guitar/bass running into input of loop 1 on gcx and 2nd guit/bass running into the return of loop1, so switching loop 1 on or off selects between the 2?
Same idea for pedal switcher...
Ground Control Pro
GCX Audio Switcher
Pedal Switcher
Fender Basses
Markbass LMII
Schroeder Cabs
A myriad of pedals
Re: Using Pedal Switcher or GCX as an A/B switch
This can be done, however as the Return jack is Ground Lifted you will have to somehow re-establish the ground connection. This can be done inside the switcher or by connecting the sleeves of the two incoming instrument cables together.
stoneboy26
Thanks John - that would explain the noise I get then!! Thought it was a ground issue of some sort. I noticed if I run it through another pedal and into the return jack I am alright, which must be doing good things with the grounds - but not really practical.
I am quite happy at the moment just muting and switching basses so might save doing any work to the unit itself for the time being.
Ground Control Pro
GCX Audio Switcher
Pedal Switcher
Fender Basses
Markbass LMII
Schroeder Cabs
A myriad of pedals
