the rack set up
Bahamafornian
the rack set up
Post by Bahamafornian »
still trying to get te slight hum sorted out, i live i the Bahamas, so its not so easy just to send this out and have it checked and finished by a pro, however that is where i am at,....
drawer 2
drawer 2
drawer 1
drawer 1
rack
rack
rack 001.JPG (121.31 KiB) Viewed 3242 times
Re: the rack set up
Dude... everybody knows that gear hums in the Bahamas. You can't have such fine rum and awesome weather AND gear that doesn't hum!
Bahamafornian
Re: the rack set up
Valid point!
Hum is gone, just have loop 8 issues, when engaged the volume drops off, and won't switch back occasionally, turn off a reset then it's fine.
Re: the rack set up
What do you have in GCX Loop 8? Do you get the same problem if you run a cable from GCX Loop 8 Send to GCX Loop 8 Return?
