At this point, the only thing I can think it might be is a bad midi cable to the Whammy. Midi path is actually simple: GCX->M4->Axe->Whammy. I tried having only the Whammy in the MIDI path and it still didn't work. But I used the same cable so that's why I think it's bad. I'll try a different cable when I get home.
Thanks Josh.
Dave
GCX With a Ground controll programing
- Site Admin
Re: GCX With a Ground controll programing
If the Axe Fx is responding to the GCP, then you know the MIDI cable there is working. Unplug it from the Axe Fx and plug it into the Whammy.Cudbucket wrote:At this point, the only thing I can think it might be is a bad midi cable to the Whammy. Midi path is actually simple: GCX->M4->Axe->Whammy. I tried having only the Whammy in the MIDI path and it still didn't work. But I used the same cable so that's why I think it's bad. I'll try a different cable when I get home.
Thanks Josh.
Dave
We've got to stop meeting like this.
But it's so sexy.
Bad MIDI cable for sure. Going to GC tonight. Now the last hurdle is to get my expression pedal to go from 0 to 127. For some reason it tops out at 125. Thanks Josh!
Dave
Dave
Any reason to think the Boss FV-500H is not "compatible" with the Ground Control Pro? Boss seems to think so.
Anyone else using one here?
Thanks.
Dave
Thanks.
Dave
Cudbucket wrote:Any reason to think the Boss FV-500H is not "compatible" with the Ground Control Pro? Boss seems to think so.
Thanks.
Dave
The Boss FV-500H should work fine with the Ground Control Pro via either connection method (Volume In/Out with an Insert Cable or Expression with a Stereo Cable) however, it will not work with the original Ground Control. If it isn't giving a full sweep then you may have to adjust its potentiometer slightly if you can get to it. Good Luck!
I'll try the In/Out jacks with a "Y". Then I'll try opening it and getting to the pot.
Dave
Dave
I opened the pedal and no matter how far I turn the pot it just doesn't send anything over 125. I'm going to get a pair of Y cables tomorrow and try using the In/Out jacks.
