Well, this isn't a real high priority for me right now, but when I do get around to testing it, I'll be sure to post the results.a2dconverter wrote:Hello nyteowl...
I like typing so please keep the questions coming...
The best way to see if everything will work without hum is to try it!
You can't hurt anything so, if you have a hum after connecting everything as you want, then use a wire or Breakout Box to connect the RTN and OUT grounds.
If you still have hum then there is another loop somewhere that you will have to trace..
good luck
Joe
GCX CONFIGURATION DRAWINGS
Re: GCX CONFIGURATION DRAWINGS
Can't we make use of the two guitar inputs/outputs and then tie each one to in/return respectively? Although that means that only one guitar would have been buffered?
