a new pedal-rack...
Re: a new pedal-rack...
to get the GCP velcroed, you have to open the unit and then remove the four rubber feets.
mibu
web shop: www.urmascapaturma.ro
youtube channel: http://www.youtube.com/user/mibutzu
mibu wrote:to get the GCP velcroed, you have to open the unit and then remove the four rubber feets.
Ah-Ha, I'll give it a shot~
Hmm, Looks like this is more difficult than I thought..
- Contact:
Hey man,
Great looking rig and super clean. I've got two questions if that's cool:
1) What is the brand of the cream coloured pedal board in the 6th pic? I'm setting up my new rig at the moment and that looks like the perfect size for me.
2) On the updated board there is what looks like a Midi splitter? What is that?
Robbydanger.
Robbydanger.
hi robbydabger
- the pedalboard is an older version of a Pedaltrain
- the midi splitter is a midi splitter from Midi Solutions, called Quadra Thru (very handy when you have to send midi to multiple units that have no midi thru connectors)
mibu
I simply drilled 3/4" holes in the board to clear the rubber feet, YMMV.mibu wrote:to get the GCP velcroed, you have to open the unit and then remove the four rubber feets.
Dom
WOW MAn!... Very Very Nice looking!...
I wonder dough, could you please post the routing on the 2 GCX's??
I'd apreciated
PS: U could use one of these forms:
http://www.voodoolab.com/gcxdiagrams/bl ... heet_p.pdf
I'd apreciated
sorry labana, have no time to do a schematic for the routing, but all is very simple - all the pedals are in series. plus the midi circuit, which controls the 2 gcx, the lehle switcher on the pedalboard, the whammy and the delay. the main concern was the ground loop noises and this was solved by using transformers to galvanic separate the gcx units from the rest of the circuit.
mibu
Hey Amigo!!
Thanx any way, I apreciate your posting!
I just have a little question, why are you usig this connection on the picture I post!,
Do you really need to go over those in/out/thru ??
http://dany-labana.com/Transfer/LABANALIVE/PLUGS.tiff
- Attachments
- PLUGS.tiff (15.37 KiB) Viewed 17648 times
that’s because I used the input buffer on the first gcx and the input signal comes at the rear of the unit, so it must be wired to the front to go to the buffered input.
mibu
