Can GP work via link with GCP ...?
LFilippi63
Post by LFilippi63 »
Hi there,
I have both a GC and a GCP and I was wondering if they can work together via link.
My question is related to the fact that having two different operating systems, maybe could possibly be damaged?
Thanks.
Luca
Re: Can GP work via link with GCP ...?
The Original Ground Control does not have any of the Link Modes... it doesn't even have a MIDI IN ;)
You can send Program Changes from the Original Ground Control to remotely recall presets on the Ground Control Pro. This would be just setting the original Ground Control to have its one MIDI Device be the Ground Control Pro, then in the MIDI settings on the Ground Control Pro you would enable Program Change Receive.
LFilippi63
Thank you so much John.
I didn't realize that the GP didn't have the Midi In (also because it's difficult to use), ... oops ;)
